What was that about being careful who you listen to on the internet LOL…
If the MC is leaking, kiss your brake booster goodbye. Brake fluid will swell the diaphragm in it.
No not Necessarily immediately nor necessarily completely. And if it it were the exhaust would smoke and you would small the burning brake fluid. Work on several flooded boostersDoesn't matter. Engine vacuum will immediately pull the brake fluid out of the booster, into the intake manifold to be burned...LOL...
Why didn’t you opt and would have made more sense to pull the booster split the case and at least cleaned if not replace the diagram.Not necessarily, I've just evacuated the booster as much as I could & replaced the MC with great success on many GMT800/GMT900 trucks without issue.
Yes, it does.
I'm dropping it off later today at a shop that I trust. 2 bottles of fluid in 3 weeks, not one drop on my garage floor...
Frustrating...
+1 and diaphragm will be shot as the fluid will swell the hell out of it. And I have never found a replacement diaphragm for a brake booster so you are replacing the entire booster.Doesn't matter. Engine vacuum will immediately pull the brake fluid out of the booster, into the intake manifold to be burned...LOL...
Yes, I wonder about this too. Burning brake fluid has a distinct, strong, nauseating odor you'll never want to smell again. If the engine were burning it at the rate the OP is losing it, he'd smell it. With today's brake systems, taking the vehicle to a shop is the best advice.No not Necessarily immediately nor necessarily completely. And if it it were the exhaust would smoke and you would small the burning brake fluid. Work on several flooded boosters
The diaphragms are available while not really so much advertised on the retail level I get them through various wholesale suppliers which mostly sells to rebuilders. But they are available. You can get them through your local auto parts chain if you have a good Parts countermen also through NAPA parts distributors/retailers. You can also contact brake part component companies that offer new brake boosters and they may sell to you?.+1 and diaphragm will be shot as the fluid will swell the hell out of it. And I have never found a replacement diaphragm for a brake booster so you are replacing the entire booster.
wow ok That is amazing. This is absolutely something I have never seen or heard before. wow!!!!Turns out the brake line from the ABS system that runs behind the gas tank has a small hole. It's been filling the frame. The gas tank that I just filled will need to be dropped to replace the lines...
with you dude seen it soooooo many timesDoesn't matter. Engine vacuum will immediately pull the brake fluid out of the booster, into the intake manifold to be burned...LOL...
glad you found itTurns out the brake line from the ABS system that runs behind the gas tank has a small hole. It's been filling the frame. The gas tank that I just filled will need to be dropped to replace the lines...
What are the odds?
Well glad you are getting it fixed and THANK YOU for updating!
How did that happen? I know GM trucks have a tendency to eat through brake lines if they see road salt or similar things in the winter.Turns out the brake line from the ABS system that runs behind the gas tank has a small hole. It's been filling the frame. The gas tank that I just filled will need to be dropped to replace the lines...
Better brush up on how manifold pressure works . If you tested for your parts counter position it’s in the book . I use to give classes for another auto parts chain.with you dude seen it soooooo many times
