2001 Blazer. rear pads were frozen in the caliper bracket (they didn't fit, and whoever installed them just hammered them in). so for several years the rear calipers were not operational.
upon replacing the pads and bleeding the brakes, dark green slime came out of the rear bleeder screws. a few pumps and it ran clear.
I then proceeded with a full brake fluid flush. but 3 months later all the fluid turned green, even in the master cylinder. so I flushed again, this time with about a gallon of brake fluid. now 2 months later the fluid is dark green again, and there's a slimy green coating covering the inside of the master cyl reservoir.
what should be my next move?
can I drain the master cyl and spray some brake cleaner in there to clean up the insides, and then flush the system again with 2+ gallons??
