On our 3.5L Olds Aurora I replaced the ATF (Dex3 spec) back in the spring of this year and a couple thousand miles ago (probably 2-3k) with Napa Dex/Merc fluid. Did the pan/filter method which supposedly on these trans does get the vast majority of fluid- spec is 7.4qts capacity and it took 7.0qts to refill.
Checked the dipstick yesterday and noted the fluid looked very dark, which I know does not really mean a thing with ATF but considering the low miles on the new fluid combined with the high miles on the old fluid I was wondering if its worth spending the $25+ on a UOA, if its better to just do another fluid exchange or maybe not worry about it at all. Trans seems to shift pretty good, certainly hasn't changed at all.
