Decided to change the rear fluid in my '23 EV6 GT early at 23,000kms. Just like i use to do in F150s, id change out my rear diff oil early.
The ATF spec is SP4M-1.
The factory fill ATF came out cloudy and dark purple. Not use to seeing ATF go this cloudy. When i serviced ATs, unless there is an internal issue, the old fluid is usually somewhat clear. I will be sending it out for UOA to compare to new fluid.
I will change out my front fluid. Would be interesting to see if the fluid condition is similar. I mostly drive the car in Eco which disconnects the front drive... I occasionally use GT to blast from a stop for fun.
The OE fluid is very expensive in Canada at $40/L.
These oil brands carry the spec
Valv Multi Max Life
Amsoil Signature Fuel Efficient
Royal Purple Max ATF
I would have been confident to replace it with any of the above, but id like to know what happend to the factory fil before adventuring out of OE fluid.. are the gear reduction boxes hard on ATF? Not sure if a multi spec fluid would be a good idea. UOA & VOA needed to find out...
Valv Multi Max Life
