Originally Posted By: AITG
For the sake of discussion: how hard is it to swap the gauge units? I would want to verify that some of the 6 psi difference isn't just variation between the two displays.
It's a 30 second job. Good idea. That's something I hadn't thought to do, but I will. However these are very accurate stepper motor type gauges so I predict there will be no difference.
No problem. I'll send you a bill ;-)
I've seen hundreds of hours spent chasing 'problems' indicated by gauges that turn out to be a gauge problem. We have a tendency to believe any instrument - human nature, I guess. Think Three Mile Island, for example.
UPDATE: Good idea but when I swapped the gauges, I realized it wouldn't work because with the Isspro Performax system, the gauges are daisy chained on one wire (from a signal processor) and coded to read only the signal it was programmed to read.
Tried my first datalog a short time ago. Can only get the laptop to accept about four minutes of data for some reason (working on that) but on the cold start with oil temp at only about 44F, initial DP was 6.9 psi, even when the engine flared at start. When it quit recording, DP was 5.9 psi and oil temp was about 90 degrees.
