I must have been ignoring youI've posted a dozen times in this thread
I think it was when you said "positive displacement" about the vacuum pump.
I commend you for attempting this, but unfortunately it’s not going to get to the “Elephant in the Room”….If you picked up 3 filters of the same model, for example, I think it's a workable assumption to consider the restriction from the media to be roughly equivalent among them. A difference in pressure differential would then indicate a difference in flow rate through media tears, bypass plate seal failure, or other leak sources.
Bypass leaking has at least two effects. First, it lowers the efficiency of the filter at all particle sizes by an amount that is proportional to the fraction of flow that goes through the leaks. Importantly, that means there is no longer any ~100% filtration rate for a reasonable particle size. If you check out the Ascent testing, the Fram, RP, AC-Delco, and Purolator filters were all nearly 100% effective for particles above 35 microns. That would not be true for a leaky filter (and actually, looking at the graph again... I wonder if the Wix was leaking.)How does this particular bypass leak impact filtration…in a working filter…not on paper.
How does this particular bypass leak impact filtration…in a working filter…not on paper. In my humble opinion the answer could be had by having a BR particle Endurance filter test performed AGAIN, only with a flashlight test post procedure. If it’s a leaker as I suspect, then there should be a follow up test with the same filter type which would be “sealed” in the potential leak area with epoxy prior (no cutting), and test again for filtration with a post flashlight test to confirm non leakage. THEN and only then, can we compare filtration of leaker vs non leaker in the same model
True,What this test can do is help identify the filter that likely has the least leakage from a batch, and I think we can all at least agree that less leaking is better.
Some vacuum pumps are positive displacement ... do some research.I must have been ignoring you
True,
But this still begs the question, is this particular bypass leak a “deal breaker”….enough for the Endurance Filter (Ultra..Amsoil..RP…etc) to relinquish its status ask a top performing filter?
Then why even conduct it? All you're doing is comparing the vacuum level of the same filter brand/model to each other without knowing anything about what's going on inside them. If you tested a modified filter to make it a 100% non-leaker (a baseline control filter) then you might have something that would be more informative.This test also won't tell you if a filter is leaking or not.
Like said before ... the one that's the "best" could still be leaking like a sieve compared to a 100% non-leaker.What this test can do is help identify the filter that likely has the least leakage from a batch, and I think we can all at least agree that less leaking is better.
Probably because you offered no explanation (like you did this time) of what you did and what it represented.I posted this is another thread and nobody commented.
Here's a little inside info for this discussion. An ISO test lab bought some WIX XP/NAPA Platinum filters back when the manufacturer claimed the efficiency was 50% @ 20u. After the bad press got out, they removed the efficiency off their website, and if emailed or called they told you (I did this myself) that they efficiently was "proprietary".Note I have inserted a second yellow line to reflect where the Fram Endurance would be with 10% volume of oil bypassing the filter element.
Mathematically speaking, it is true (I did a spreadsheet to be sure), that if 10% of the oil goes through a permanent bypass, then for a filter that was near 100% efficient, you can say that it is now 90% efficient.
The issue is that it drops 10% across the entire micron range.
Well, all of them being within a needle width of each other on the vacuum gauge may not mean much if anything really ... some of that could be caused by other factors, like slight differences in total media area, or the bypass valves themselves are seated slightly different off the assembly line. So it's hard to distinguish the very slight delta vacuum level cause without knowing that other factors mighty be involved. If you knew the vacuum level on a non-leaker, it might give more insight to just how much these are leaking. What's the delta vacuum between a leaker and a non-leaker. You will never know unless you test for it.All you had to do was make it to the end of the sentence lol. Surely you can at least agree that less leaking is better than more leaking?
You would have the same variability in media regardless of leaks. The assumption of media consistency is unfortunately necessary.Well, all of them being within a needle width of each other on the vacuum gauge may not mean much if anything really ... some of that could be caused by other factors, like slight differences in total media area, or the bypass valves themselves are seated slightly different off the assembly line. So it's hard to distinguish the very slight delta vacuum level cause without knowing that other factors mighty be involved. If you knew the vacuum level on a non-leaker, it might give more insight to just how much these are leaking. What's the delta vacuum between a leaker and a non-leaker. You will never know unless you test for it.
They then cut some new ones open and sealed up everything except for just the media cartridge, and re-tesed them per ISO 4548-12 again, and the efficiency was around 90% @ 20u after fixing the internal lead(s). So internal leaks can certinaly impact the overall efficiency as they demonstarted.
If I was going to make a baseline control non-leaker filter, I would first test it before modifying to get that reading. Then I'd modify it to be 100% sealed around the leaf spring to end cap interface. Then retest it to see the effect of sealing the leaf spring. Everything on that filter would be exactly the same except for the leaf spring sealing area. If you see a decent change in the vacuum level, then you at least have a delta that correlated to only the leaf spring seal.You would have the same variability in media regardless of leaks. The assumption of media consistency is unfortunately necessary.
If one of these filters happened to have a tear in it and came in at half the pressure differential compared to the others, you aren't going to come back with "Useless test, needs a baseline," right lol? So even if you disregard the small differences revealed in the filters I have on hand (which is understandable since, as I said, this was a quick setup that would benefit from a higher flow rate), there is still value in identifying major defects like media tears before installation.
Having a tear in the media on an new unused filter is pretty unheard of. Something I would never worry about. I dropped the media tearing Purolators like a hot potato when that all hit the fan, lol.Do you have another way to identify a tear in a filter you want to end up using?
Well of course ... like the meme says:It was a test! Btw, it's still going to filter down to 5 microns better than most other filters .....
I just looked at the correspondence info I had, and it went from approx 50% @ 20u to approx 90 @ 20u.I knew about the third party testing but didn't remember how much it improved once they fixed the filter. 90% at 20 microns is quite the improvement.
NoWith no wire backing, is 2 still considered one of the OG Titaniums?
So what's the progression?
