Just purchased yesterday from Lexus dealership.
Everything external looks great.
Vacuuming out yielded no debris from the filter itself.
ADBV and plate-can interface had zero leaking, up to the 30 PSI I tested.
Gasket comes pre-lubricated and has a good profile for sealing. Burns with black smoke.
ADBV is very pliable. Burns with white smoke and ash, so probably silicone.
Pressure differential is shown in comparison with other filters that fit the same vehicle, although the other filters are quite a bit taller so comparison value is limited. It is interesting though that the smaller Toyota is much less restrictive that the larger Frams.
Total filter surface area, excluding the glued ends of the pleats, is 2 * 43 pleats * 71.1 mm * 20.8 mm = 127,184 sq mm = 197 sq in.
Case is about 0.5 mm thick.
Information on bypass leaks in first comment.
Gasket
Relative pressure differential
Lines on scale are 0.5 mm spacing.
Gasket
