I'm sure I will jynx myself and the problem will come back.
But my truck (2001 F-350 5.4 with 125K on the engine) had a bit of an odd issue. When I would cold start it, it would run good for 10 or 15 seconds, then as soon as it would go closed loop - confirmed with scanner - it would get an awful multiple cylinder misfire for a minute or 2. Once it would figure itself out, it would run and restart smooth.
I checked fuel pressure and it was good. Couldn't find any intake manifold leaks - long term fuel trim for bank 1 is at 10% . It also has a blown out passenger side exhaust manifold, but this problem was around before the exhaust manifold blew out.
The fuel gauge got stuck at 3/4 tank. I dumped 2 bottles of techron in so I could get the recommended amount for my 35 gallon tank. I heard it works on some vehicles. After 2 days with the techron in the tank the cold start issue went away. The gas gauge is about as good as it ever was, now. That is to say that it was never great to begin with, but it at least reads more than one position.
The exhaust manifold will be replaced soon.
I'm just having a hard time believing that a fuel system cleaner actually did something
