Originally Posted By: NibbanaBanana
Everything that I've read and heard, here and elsewhere, is that the majority of engine wear comes at startup due to lack of lubrication.
Not trying to be pessimistic or anything. Just wondering.
You haven't read any of my threads ?
Just 101 and some claptrap ?
The majority of wear occurs during warmup, while there's plenty of oil...and it's flowing.
For a 2 hour run, 75% of the wear occurs in the first 6 minutes...for a number of reasons, and the contribution from no oil pressure is small, provided it doesn't run too long (e.g. improper selection of "W" rating in an extremely cold environment.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4048953/75__of_wear_occurs_at_startup.
The bearings will always be full of oil due to capillary action, yes you can squeeze that out pretty quickly.
The oil sits in the piston rings for whole minutes with the engine running, so there's plenty there, even dry after an oil change.
The oil in service forms a protective tribofilm, which protects in the boundary lubrication regime, again offering protection for this case of misadventure.
I'm never going to say that the OP did his engine any favours, but it's going to reduce the life of the engine by a tiny amount in his scope of ownership.
