Originally Posted By: WishIhadatruck
Originally Posted By: daves87rs
Meijer's. 5.49/qt. Valvoline Full syn Dex VI.
That is what I've been using. In the opening post you mentioned that you only find Valvoline that is high mileage. Valvoline doesn't make a Dex VI that is hight mileage that I'm aware of. Perhaps a Dex/Merc Maxlife but the Dex VI is not Maxlife or high mileage.
My mistake...I was looking at Dexron/Mercron at Autozone. I ended up getting the Valvoline Dex VI that is 100% Synthetic, dropped the pan and changed the filter and it took 5 qt's, I also installed the B&M drain plug kit and after I drive for another month or so I am going to drain it and replace another 5 qt's. This is an 11 qt system so I figure doing this will give me about a 65% new fluid exchange...so far with just the new filter and 5 qt's of Dex VI the transmission shifts much much better, it is a lot smother and it use to hunt for gears between overdrive and 3rd going up a steep hill, now it will just downshift into 3rd and hold it until I crest the top and then shift back into overdrive. I am very pleased with this fluid so far, we will see what happens next change when I get more of the old fluid out.
