Originally Posted by MolaKule
Originally Posted by LeakySeals
Anybody have info for the suggested alternate compatible fluids like Havoline? Here's a ACDelco full syn and Valvoline maxlife multi-vehicle compatible fluid comparison. The maxlife multi-vehicle is pretty thin compared to ACDelco Dex VI. Which could spell trouble for a high mileage transmission. It's not like the engine, extra care needs to be taken when selecting a transmission fluid. Would be nice to know.
Maxlife Dex/Merc ATFÂ
cSt@40*C - 28.82
cSt@100*C - 5.91
VI - 156
ACDelco Dex VI
cSt@40*C - 30.6
cSt@100*C - 6.1
VI - 152
Golly, where have you guys been where we discussed the fact that a 0.2 cSt to 1.5 cSt difference in ATF viscosity will not change anything?
We have discussed in various threads how the Dexron VI, while starting out a viscosity of about 6.0 cSt or lower, has much greater viscosity, FM, and oxidation stability than any previous Dexron specs.
The Dexron III series starts out at about 7.2 cSt and shears down to 4.5 cst before 30k miles.
I do remember that. I also remember how my Dex III AWD transfer case would not turn right using any variation of Dex VI. Had to be Dex III to operate correctly. And an older GM auto that required Dex III that everyone promised me Dex VI was "backwards compatible" with. Nope, would not shift into 3rd! Went back to Dex III, was fine again.
OK, perhaps its not the small viscosity difference. I trust you. But something else, maybe an additive is enough to mess me up both times i substituted Dex III with Dex VI. Something similar is happening with the new 8 speed GM truck transmissions. A small difference in the fluid results in a recall. I'm snakebit substituting ATFs.
