- Joined
- Nov 21, 2024
- Messages
- 136
You are not overthinking it, Dexos D is picky by design. For that 3.0 Duramax, the safest move is still a Dexos D approved 0W20 because it is tuned for the DPF and fuel dilution control. Low SAPS matters more than chasing other specs.
If you cannot find Dexos D, ACEA C5 0W20 is the closest functional match. C6 is fine too if it also meets GM diesel requirements, but do not jump to thicker oil. The engine, emissions system, and oil pump are all calibrated around 0W20. Going heavier in Texas heat sounds logical, but it can actually hurt flow and DPF performance.
Using another certification like Porsche C5 or Dexos 1 is not something I would do long term. Short term is unlikely to hurt anything, but for regular use stick to Dexos D or ACEA C5 0W20 from a major brand. Availability is improving and it is worth waiting or ordering online rather than experimenting with viscosity or specs.
You haven't been following the data at all, have you?
