On a lark I picked up this older Delta Rockwell bandsaw. Model 28-113, with 10" wheels, I think 1971 or 1972 vintage. It looks like it needs a thrust bearing 1231546 and the guide blocks, as it's blowing all sorts of sparks in that region at the moment. Is there a recommended place to get parts for this? I'm guessing it's worth putting a couple parts onto.
Don't see it real well but there are grooves worn into the blocks... although now that I'm typing the fix is obvious: flip them around! duh. Anyhow, you can see the roller bearing is heavily worn, and it does not spin smoothly.
