JHZR2
Staff member
- Messages
- 45,338
- Location
- New Jersey
Hi,
The car is a 1991 BMW 318i, with the M42 4-cyl engine.
I currently use pennzoillong life 15w-40 in the car. I like the oil, but have just two issues with it: I wouldnt trust it in the winter time, and I get tapping noises at full temp, meaning that maybe my oil is too thin to keep adequater pressure in the hydraulic tappets.
That said, I am thinking it may be smart to change to M1 15w-50. The car was speced for 15w-40 or 50 or 20w-50, so I think the 15w-50 synth will be a nice fit. Plus, I would be OK with leaving it in the engine through the winter, because it is a synthetic and has better flow properties.
The problem is the car is used for short trips, so I would feel better using something cheaper. I was thinking of maybe trying delvac 1300, since they claim it also passes the spec to be a 10w oil in the cold. Maybe I just need an oil that has a bit thicker viscosity at temperature?
I do have a 2.5gal -4qts jug of longlife, purchased from wal-mart. Not sure what I ought to do with it, should I switch to the mobil1... Maybe use it in lawnmower service.
Maybe this is a no-brainer (because im cheap and dont want to not use the pennzoil, once I switch, itll be semi-permanent) but I do want to rid myself of the tapping, and my oil change is due...
I just need some help making the decision of what to do next...
Thanks
JMH
[ July 09, 2003, 11:56 AM: Message edited by: JHZR2 ]
