What you are describing is identical to my 2008 3/4 ton Chevy. Yes, there are 11 grease points. I said in a post last week, that’s one more than 10, for all the Spinal Tap movie fans.
They all come with zerk fittings. If the vehicle is put on ramps a shade tree mechanic can reach them all. The toughest one to reach is the idler pivot assembly. You definitely need a grease gun with a flexible hose. Those straight steel tube ones will not work. I can reach all of mine without taking off the skid pan, but taking it off will make it easier. To make that job quick, buy an battery impact driver with the attachment for sockets and it will zip them off. Mine is a Dewalt and is one of the most versatile tools I have,
Ok, if you don’t want to do it yourself, take the vehicle to a DEALER or Indy Mechanic and have the job done. I would not have an oil change done at the same time because all they will do is have you go through the quick change lane and have those monkeys change the oil and lube a half dozen zerks and send you on your way. Have the service writer mention 11 zerks. Not 9, not 10....11. That’s one more than 10.
Good luck.
