Data on AC Delco filters
Michigan
I have been criss crossing the interwebs looking for a site with data on individual AC oil filters. similar to the info that Wix has on their site, thread size, diameter, length, bypass psi, etc etc. I have come up empty.
Has anyone seen this ? I used to love Wix because of their quality and the info on their site but not so much anymore.
ZeeOSix
$100 site donor 2022
PNW
Think you and others have come up empty because it doesn't seem to exist.
South Carolina
@64bawagon this info is on the ACDelco site. It's a little confusing and hard to find, but the specs link is at the bottom of the page for each filter.
Edit: Rockauto also has this info on their listings.
Here are the deets for a PF2057.
64bawagon
Michigan
Thanks, I did find this info, it has everything but bypass psi but I found that in other sources. Mainly I was trying to confirm the similarity between the PF64 and PF63. I have quite a few of the PF63 and I would need to buy the PF64 for a family member. As far as I can tell they are the same except for length which on the new application (equinox) wont be an issue.
4WD
$50 site donor 2023
Texas via IAH
This seems logical since GM likes the higher settings
South Carolina
Weird! Apparently ACDelco lists the bypass setting for some filters (like the PF2057 that I attached above) but not for others (like the PF63/64).
I like Fram a lot better; not because their filters are necessarily better than ACDelco, but because their site lists all the deets for every filter.
Cali
Why? anything you read on this site scared you away.
