Dash Cam hard wiring question
NJ
I plan on hard wiring a dash cam into my car by tapping into the fuse box. One wire is Ground, one is switched Accessory and the other is Battery so the cam goes into parking mode when the car is turned off. The battery wire on the cam has a little inline switch where I can select how low I would be willing to let the battery voltage drop to before the cam turns off.
This I don't care for and was wondering if I couldn't just connect the "battery" fuse tap to another accessory fuse and just have the cam turn off when the car is off and not worry about some sort of malfunction that drains the battery.
I turned parking mode off on the camera. It took me a lot of trial and error to find fuses that acted the way I wanted them to act. Many surprised me by being hot when the car was off.
I don't think you need to connect that battery wire at all if you aren't worried about the wake up mode for an impact when parked. I would be cautious about tapping into a critical circuit as well. Try to avoid anything involving the ignition or the fuel pump. For my Ram I found a sunroof circuit (accy) and an underhood light (constant) to tie in to.
Leave the battery wire off, or connect it to the accessory source if needed to turn on camera.
instructions with the dash cam may provide the needed info.
Note: There are many modern vehicles that have power at the rear view mirror. Often there is a connector adapter for dash cams avial on Amazon or elsewhere.
Yeap, Dongar
Problem with using a circuit in the rear view mirror unit is that the camera may overload the circuit and cause the mirror's circuitry to misbehave. Modern car makers design their electrical circuit to handle a specific load without much headroom.
OT: car makers are starting to switch to aluminum wiring to reduce cost and weight.
Both my vehicles are hard wired and the cameras come on if the vehicle is jarred. They often sit for a week with no issues. I dont think the draw is much.
I've had Dashcams in 3 different cars connected to the rearview mirror with the Dongar adapter, never had a problem.
my dash cam will run on 5watts. so load is less than .5amp not worried about overloading a mirror circuit.
On my dash cam app I can turn the parking protection on or off. I normally have it set to off and only turn it on when I park somewhere other than home. It also has a setting for how low you want the battery voltage to get before it automatically shuts down the parking protection. I set mine at 12.3 volts.
tap the radio or fuse for an external amp. that will for sure be switched or turn off when the key out or drivers door is opened.
My dash cam draws, at a maximum, 1.5A.
Knowing 12V electronics at work, it is rated for 1.5A but won't constantly draw that much. You would be out of charge and won't start your car if that's how much it constantly draw.
Having said that. If you insist on getting it connected to a constant on 12V, that still has fuse protection, probably tapping into the overhead light circuit is the easiest and lowest risk. It should have power constantly at the on off switch. Find the nearest one and run a wire to it.
My car doesn't have powered mirror but if yours has that's a good place too.
I specifically said it (can) "draw" that 1.5A "at a maximum". I hope no one would interpret that to mean a constant or continuous 1.5A load.
I understand what you mean.
I have worked with 12V 1.5A constantly in the last 3 years. I know how much power is that. There is no way a dash cam would draw that much other than some inrush current when you first plug it into the cigarette lighter socket for a few milli seconds.
