I am planning to install a LED lighted emblem to my car. Here is the fuse box -- I will be running the positive wire to the fuse box, and I am hopeful to discover one of the free spots that are on when the key is turned on.
I would ideally have a clean install as if it's a factory install, i.e. I do not use a fuse tap but the slot for the fuse with the wire attached somewhere underneath.
Unfortunately, all the instructions I find are either with a fuse tap or or a fuse piggy back tap.
So... how would I pull out the yellow fuse holder and attach the wire?
