Originally Posted By: BuickGN
Originally Posted By: Drew99GT
There was still residual oil though on the engine parts; probably more so given the engine was last shut off not more then probably 10 minutes prior to the no oil pressure event.
A cold engine that's been sitting for several days - the oil has had that long to drain and drip off parts.
Just a thought.
I'd wager a bet that some of the extreme cold starts I've witnessed with my car did way more damage then idling for 60 seconds with no oil pressure (on an engine that's going to have a lot of oil still on the parts, and one that is warm).
Do you realize you're comparing a minute with no oil pressure or flow to a single cold start? The coldest cold start is not going to starve the engine for oil for more than a second or three at most.
I've torn engines down that sat for a year without being started and they still had oil on the cylinders and in the bearings.
This thing was run for an entire minute! Any oil that was in the bearings and on the cylinders from shutdown was gone after a few seconds after the pressure failed to arrive!
Do you realize how the oiling system works? The method in which the cylinders are splashed?
Do you realize that you're a condescending [censored] hole?
Yes, I know how the oiling system in an engine works Mr. Diesel Jeans.
I've seen plenty of cold starts at 20 below or colder where it took a wee bit longer then a second or 3 for oil pressure to register.
Just a thought.
