Originally Posted By: cmorr
Disagree, this is the reason why moisture is an issue in a hydraulic brake system. Unlike brake fluid water is easily compressible
So have you perfected cold fusion as well?
Dude, water is a fluid and is NOT compressible. The reason moisture in a hydraulic brake system is a bad thing is that water will boil under the temps encountered in a braking system, and water causes rust and corrosion.
