Interesting where are you getting absolute numbers on wear, deposits and fuel economy between the two standards for comparison?C2 = Much higher soot handling requirements. Slightly higher wear and deposit standards.
D1G3 = Higher oxidation, after treatment and fuel economy standards.
Okay, I just wondered where the "slightly" statement came from.Just my opinion that D1G3 has more rigorous standards in some areas and C2 in others and that D1G3 doesn't have any real soot thickening requirement. Everyone will certainly have biases as to what test they consider more rigorous as they are often different.
My opinion is that neither is a particularly high bar overall.
The items listed in your link is not a comprehensive listing of all the testing parameters especially for ACEA C2. There are many more.
You are the expert in regards to this. I am all ears.The items listed in your link is not a comprehensive listing of all the testing parameters especially for ACEA C2. There are many more.
11 is one better than 10, right?
You do make a valid point. I should have worded more properly. I meant to say which has better tests to show it is a better oil rating?No particular opinion at all but I use ACEA C3 oils in all my cars now. I was pointing out that the links you gave were an incomplete listing and making a comparison based on the number of tests listed was not a valid means of comparison.
Even if it was valid it would be predicated on the results of the tests, not the number. Right?
