So the used 2001 Ranger 4x4 I picked up has a leaking seal at the front axle where the CV half shaft connects. Since I've got to pull the half shaft to replace the seal, is there any harm in replacing the boots and re-greasing the joint? I've never had to deal with CV joints before. I did check and the only replacement axles are aftermarket so I was hoping to get the original ones to last for a while.
Thanks!
Thanks!
