I accept and go by what Jim Allen said about endcap poppers when he posted here. As long as the potting intact and the leaf spring holding the element firmly, ie. as designed, then there is no oil bypass. Looking at the potting here, all looks as it should be and no loose element noted, so no oil bypass.
And IMO, no different than the significantly less, narrow area in the Fram fiber offerings covering the centertube ends. Even when the centertube ends exposed on dissection backers say it's covered during use with leaf spring function before dissection. I don't happen to accept that view in every case that have seen posted here, but if one unconditionally accepts that point of view, same would have to apply here.
That said, ideally one would prefer not to see/have an endcap popper but if conditions as described, highly doubtful it presents a functional issue.
