[Cut Open] Fram XG7317 - 12,045 mi
Originally Posted by goodtimes
Originally Posted by ZeeOSix
Maybe sometimes someone can't recall all hundred thousand+ threads that they've read over 10 years. People who accuse someone else of being a "L" best be very careful what they are claiming..
Big talker, but you didn't tell the truth when you said the particle test probably doesn't exist, as you know full well it exists. You did it again with the ISO cleanliness results, with no shame, and no apology for not telling the truth. You debunked nothing btw.. Why are you waiting for the Fram Ultra rattling thread? You know all about it as you were in it. Untruth number 3 and you're not ashamed one bit. Pathetic.
Just because I didn't know exactly what thread you kept talking about, you think you can somehow read my mind and coclude I know which thread it is. Why do you think I kept asking you to post the link? And then you start sneakily calling me a liar - just because I happened to make a comment in that old thread, so you think I'm supposed to remember that, and magically know exactly which thread your talking about? Then someone else asked to see the thread, and you instantly go find and post it - total ridiculousness.
You did notice that Mr wwillson cleaned up your abrasive accusatory post above - and you made the same accusation in another thread about the PCs. Like I said, people better think twice before making false accusations about "lying". It will not be taken lightly by me.
And if you're accusing me right now of "doing it again" with the ISO cleanliness results, then I highly suggest you go back to that thread and actually read the 3 thread links I gave, and look very closely at the data and what I posted. Here, I'll make it easy for you - read it and all 3 links very carefully: https://www.bobistheoilguy.com/foru...ter-choice-for-december-2018#Post4855718
The Rock Auto "Ultra Power" filter (the one you keep latching onto) had a worse PC than the Ultra and TG Blackstone PCs I referenced (XG and TC have the basic same efficiency). Therefore the Ultra that had a worse PC than the RA "Ultra Power" (which is obviously worse than 99% @ 20u efficiency) can pretty much be concluded as a fluke IMO. Anyone with any common test knowledge would conclude the same thing - so yeah, it's a debunk IMO.
Originally Posted by LeakySeals
I had to stop using it because my 6.0 would rattle "too much" at startup. Using the TG the engine makes "normal" noises a GM 6.0 makes at startup
I had the reverse in my old school 4.3. A regular OCOD would rattle/tick, while others would not. Ultras do not, even after sitting long times.
It is dubious to me that looking at non standardized testing, where ingress and use parameters can be widely varied, is relevant.
One run being good, one run being bad, another being anything else - it's all inconsistent parameters, and doesn't necessarily indicate much. Sometimes an in situ test is valuable, because you want real world conditions. It's not clear that tells one much here, at least without statistically significant data.
Therefore because of the nonstop bickering and drama, I'm locking this.
