Originally Posted By: Jim Allen
I think the old "conventional-only for break-in" is a hangover from the old days. Back before the new honing techniques they use now, ring seating was a big issue and a really slippery oil could slow or stop that process. Might still be true for some of the behind-the-times machine shops out there so it could be an "it depends" answer. For myself, if I plan on running a short break-in OCI, I prefer not to dump high dollar syn, so I might use a conventional for that reason. Since many new engines start with syn in the crankcase, I think that puts paid to the notion that conventional is "needed" for break-in in all cases.
I am pretty sure you are correct with what you are saying, however, from a personal standpoint, I dump oil very quick after it is fired up and run for a short time/miles. During break-in is when most of the break-in materials will be present, so why spend on expensive oil for that when it will be dumped? I dump the oil early on new cars I have bought, and I certainly do this when building a performance engine. I am into the motorcycle race scene more than cars, but this is the same guideline and my builder does from a personal standpoint, and we have much success with it. Oils are expensive enough, so I will not be breaking in with $9 plus per quart stuff only to be dumped right out.
