CRV's, are they that good?
Do Honda tech’s not build wiring harnesses? Replace connectors/ pins? You don’t often change a wiring harness at Audi just repair it.
Unlike some other brands, Honda isn't really into harness repair. More often than not, you have to replace complete harnesses. But Honda harnesses are very inexpensive compared to most brands.
Which comes first, egg or chicken? maybe they had a bad run years ago, so they got into having spare harnesses. which drove price down and thus made cheaper to replace rather debug? seems odd, by comparison, then again debugging wire harness issues… probably makes that the cheaper option.
I have a 2003 crv that has been in like 4 accidents (deer/ moron magnet), I’ve had to replace the a/c compressor x2 the power steering pump, the vvt valve on the back of the engine leaked, fixed it now it’s leaking again. The drive shaft u-joints failed and the cat converter failed. Oh and the brake master cylinder and a brake caliper failed. The radio died and the glove compartment handle broke. All before 80k miles but it had been in several accidents so who knows. Taught my final kid to drive on it and he’s currently driving it until he has the skill to drive something better. Poor car taught 4 kids to drive, that’s a tough life lol. The car is approaching 110k. It’s actually really good in the snow. Then I had a 2008 crv bought new, it was pretty good but there was a rash of transmission issues( mine threw codes that they supposedly fixed) with that year and a friend of mine who worked at a Honda dealership warned me and said I should trade it as they weren’t lasting much longer than 100k, so I bought a Toyota 4 runner which was an awesome truck with zero issues.
Aside from an A/C compressor that went out at 90K (while driving through the San Joaquin Valley in the height of summer...), my 2008 CR-V has served me flawlessly. Engine - perfect. Transmission - perfect. Suspension - perfect. Steering and braking gear - perfect. The interior is spacious, wear-resistant, and versatile, and I find the seats comfortable. Nothing of import has broken other than that darned compressor. Yes, it's a noisy highway car. I rarely notice the noise anyway since it's on urban commuting duty and rarely leaves the SF Bay Area. It's at 109K now and should reach 113K by its 15th birthday this December. I plan to retire it in year 25 of operation.
I have a 05 CRV. My father in law purchased it new and has all the maintenance records. Looking back at them it was mostly oil changes, rear diff fluid/transmission fluid changes, brakes and rotors. 2 sets of tires changed. FIL says AC compressor is original.
When he gifted it to us 3 years ago, it had a small oil leak. Brought it to my mechanic and it was the crankshaft seal. I changed the outer tie rods, rear endlinks, f/r sway bar bushings
2nd biggest repair I had to do was a leaking radiator. Might as well change the tstat too while it's out.
3rd repair was changing the small 51r battery. It was a 3 year old battery, new when we got the CRV. It wouldnt start twice in the -40c winter we had. Charged it with a battery charger, and still died the 3rd time. I decided to do the battery upgrade from the CRV forums. Buying an oddessy tray and using a spare 35 AGM battery I had. No issues in the -40c winters for 2 years.
4th issues was the Ac condenser fan. Just changed it 2 months ago.
I'm pretty happy with this little crv.
Probably as good as it gets, in that class. Definitely versatile.
Just do 5K OCIs. I use a MityVac and swap the filter every other service on my friend Mani's 2019 EX-L.
She loves it.
Exactly my routine on my 21 CRV with extraction as well, on my last oil change in the spring with 5k on the oil the level was about1/8 over the initial fill and didn't smell of gas. That's with temps often below -10f and lots of short trips of under 10 miles.
Well, I have/had 3 CR-Vs, so here is my experience...
First of all, it seems the CR-V was designed, in my opinion, for older people (or people with back issues). Seriously...the driver seat just seems to be at the perfect height for people to 'slip' into...no climbing or falling in. Getting out is just as easy. Also, those of you have have or had CR-Vs...notice the back doors....opens almost to 90 degrees. Those with kids and child seats can appreciate that as well as older folks with walkers.
On a side note, a vehicle better suited for the older generation (especially those with walkers)...better than the CR-V that they don't make anymore...the Element, which was just a CR-V with a different body. My aunt has one and loves it.
So, had a 2nd Gen CR-V (04-06)...actually a 2.5 Gen (06) EX model with 'real time 4wd'. I had bought it used with about 89k. Had to get this one because it was blue which was hard to find at the time (for wife). I had it until about 212k miles. In the 100k+ miles I had it, I had to replace the A/C compressor clutch, a rear wheel bearing and both front compliance bushings...and of course, wear items like tires, brakes, oil, etc (and the rear diff). We used the hell out of that vehicle...used it like a truck. We made many, many trips to Atlanta...hauling back trunk load of food and stuff. Traded it in at around 212k miles because the check engine light came and stayed on...which ended up being the timing. Again, don't know the history of this CR-V since it was bought used, but when I had it, the oil was changed every 6k miles. But the timing still went out on the thing...you could still drive it, but had no power as the VVT was disabled. I'm suspecting that the original owner when too long on his/her oil changes.
Second CR-V was a 3rd Gen (07-11)...an 08 EX-L again bought used. I have to say, this gen of the CR-V 'felt' the best. I mean it felt SOLID and was so smooth. Going over bumps and rough roads...it felt bigger than it was. We bought this when it had about 60k miles on it and traded it in when it had about 120k miles on it for a truck based SUV (which I needed for work). BUT, I wish I had this CR-V back. Everything about it just felt like 'solid quality'. In the time we had it, only had to replace the tires.
Now we have (wife's car) a 2016 CR-V Touring (4th Gen) that was bought brand new. To me it feels like Honda took a step backwards. Don't get me wrong, the car is nice with all the bells and whistles (except no 4wd) and seems to be put together well, but it seems to have lost something compared to the last generations. For instance, the quality and feel of the interior materials doesn't seem as solid as the '08 we had nor does it feel as rugged as the '06. It feels delicate. The whole car doesn't feel as solid as the '08...it seems louder on the highway, plus when you close the door, you getting a 'tinny' sound instead of a solid 'thump' in the '08. But, so far, nothing has been done except oil and filter/fluid changes. AND I don't care what Honda says...the 2.4L Earth Dreams (with direct injection, non turbo) appears to have some fuel dilution issues. Every time I check the oil it smells like gasoline. So, it gets its oil changed every 5k miles, regardless.
Overall, I think a CR-V would be a good choice. My recommendation would be the 3rd Gen if you can find one or a 4th gen with the normal 2.4L, not the directed injection one...if buying used. Also, if you don't need it, I would stay away from the 'real time 4wd' systems on these vehicles....they require regular maintenance and use a Honda specific fluid.
Funny you mentioned old people my 93 old mother can get into the front passenger seat my 21 CRV unaided she cant get into my sister new Venza without help.
I have to say a couple things
Klein Honda in Everett WA is terrible. Never patronize the place - they don't support the products they sell. They are slimy and avoid any and all correspondence. They did some very questionable and WRONG things to my wife's 2017 CR-V while under and after warranty. We asked them even to pay a portion (below) and crickets.
Bellingham Honda is small obviously but they are a complete stand up organization.
To keep it brief Klein, not Honda design or manufacturing screwed up a left side wire harness. We think they maybe worked on the wrong car when my wife had it in, unsure, or they somehow tried to install some aftermarket alarm system. Complete butchers. Things wouldn't work - electrical - or not work as expecxted. I know for a fact I did not do this and no other dealer or service place saw the car in that interval.
Bellingham Honda did charge us their cost for the harness and installed it for a very nominal fee (of course something that should have cost me nothing or even have been an issue)
So after all that, the car runs PERFECTLY. It's been over a week now and zero gremlins and ALL functions behave as expected. Funny, make me like the car again!
Was this related to the A/C pressure switch harness issue?
