Cooper Sizing Issues
OH
On my dad's 12 Camry LE that comes with 205-65-16's. The only tire they have in that size is their winter tire. However, if I go to a 215-65-16 many options come up esp the CS4. I could also go to a 205-60-16 but think the slightly wider option would be a better choice. I would probably order these from DTD and have them installed somewhere maybe even the Toyota dealer. Hopefully, that won't be an issue. Thoughts, comments, other, etc...???
What about a 215/60R16? That way when you go wider you are not also going taller.
Also, why are you so stuck on Cooper? I'm pretty sure there are a lot of other quality options out there.
Get the Kumho Ecsta LX Platinum. Really awesome tires at a great price. They are basically a budget-priced Michelin MXV4.
Kumho tires are better than Cooper!
Same for fiat, only 2 tires that fit in stock size, some cooper and pirelli 195/45/16. I will go with 215/45/16 or even 215/50/16 when it's time to change, much more choices and better tires.
If you aren't dead set on the CS4's you can get Hankook Optimo H727's in the OE 205/65/16 size and they are an EXCELLENT tire. They have a $50 rebate deal going on right now. DTD has them for just $97 a tire and they are showing a whole bunch of rebates for them ( 3 in total )
$50 Hankook Rebate
$75 VISA Card( must order between June 20 and June 24 though )
$30 VISA Card if you use the CarCareOne Credit Card
So...
Tires: 4 X $97 = $388.00
Shipping: FREE
Less Hankook Rebate: -$50.00
Less DTD VISA: -$75.00
Less CarCareOne VISA: -$30.00
Total = $233.00 for 4 tires shipped to your door
NOTE - I didn't read the fine print to see if all 3 rebates can be used on one order like that but they are all listed next to the tire so maybe or maybe 2 of the 3 or something?
That's an excellent price on the Hankook's. Not to mention keeping the normal size in tact. Just had the CS4's on the previous generation Camry and my dad liked them a lot. I'm currently running some Hankook Ventus V2's on the Matrix and after 10k miles I'm very pleased with them.
I have 205/65R16 on my car and this is an oddball tire size to begin with which is unfortunate so choices are limited. When I got tires at a tire chain they had General Altimax RT in this size and I have no complaints. They really excel in there wet performance.
Yes, there are lots of tire choices in this size, 205-65-16. My '04 Altima came standard with this size(2002-04), where the(2005-06) Altima came with 215-60-16 and have stayed with it to 2012(IDK about the 2013).
Many high rated/scoring tires with good customer reviews included:
Hankook Optimo H727 *The Deal Right NOW!
General AltiMax RT
Pirelli P4
If an optional size tire won't fit in the wheel well or would rub against the strut or inside the well, DTD wouldn't list it. I am using a Plus Size(225-55-17).
Keep in mind that the 225-60-16 are a good replacement size as the two tire are almost identical in over diameter and should fit nicely in the wheel well of a '12 Camry. And, you can get the CS4's in this size.
http://www.discounttiredirect.com/direct...&vid=021074
Look into discounttiredirect.com as they have a really nice deal going on right now.
http://www.discounttiredirect.com/direct...es=1&cs=205
^^^Some good points above. And iirc 225/60-16 is the size I used to replace my 03 Altima 205/65-16 oe size. If one uses one of the many online tire size speed calculators, 225/60-16 has a very close to oe size speedometer reading. I suggest anyone considering alternative size use one, 1010 tire site even warns to make sure no more than 3% difference from oe. 205/65-16 does have limited offerings compared to others.
For sure DTD has some great multiple promos going to lower the cost, looks like some have up to 3 rebates.
Hope taking them to the dealer for install doesn't negate all your DTD savings. I mention that because that was my first thought when you said you might let them do the install. Just something to consider, I'd check price before agreeing to let them do it.
General AltiMax RT
Pirelli P4
Good stuff guys and I'd be happy with any of the tires mentioned above. The Toyota dealer charges $80 for the install which includes dealing with the tpms. The Ford dealer where I take the Matrix for oil changes charges $15 per tire and uses Hunter Road Force balancing. Which I found out when I was on the Hunter website and clicked on installers that use their equipment.
I had Walmart install the tires on the Matrix(no tpms) from DTD. Which I had to have them redone. The first guy that did them was younger and was done in 25 minutes. I noticed a wheel cover was jammed against an air stem and was low on air. The older guy that redid them tested all of them for air leaks and took his time resealing and remounting everything up. At first they were ticked at me for returning but when they noticed the air leaks they were super nice. Kind of weird dealing with attitudes first thing in the morning like that. After the winter in Clevand they held air very well.
I do read good things about the Kumho Ecsta LX Platinum's. But, I keep forgetting about them because, everytime I look at'em for my specific tire size, they're either out of stock/don't come in my size or alot of money in my size for some reason.
Just get 215/60r16 , you will induce a -1.26% error, which means you will be going slightly slower than what the speedometer shows. Lot more options in that size. The thinner 205 rated tire lowers the rolling resistance, helps them achieve their mpg target numbers. Those same cars were available a few years ago with recommended tire size as 215/60R16.
