I wanted to list some general guidelines of the various coolants. I'm not saying they are object facts but I believe them to be accurate.
Original Green- IAT Silicated and phosphate, borates. available in concentrate. Was OE. Least agressive with plastics. Tolerant of air. Protects metals well. Despite the silicates, can be used in most vehicles. Proven over several decades. Has a higher pH ~10, 2y/30k mile service, short shelf life. Less tolerate of tap water.
Original Japanese- borderline HOAT. phosphate and benzoate. available in concentrate. OE. slightly more agressive with some plastics. best only for older Japanese cars. 2y/30k mile service. less tolerate of tap water.
G-05 HOAT benzoate, borate, silicate. available in concentrate.OE used. Probably slightly more agressive with some plastics than Green but less agressive than other HOATS and OATs. compatibility close to Green with a complete flush. 5y/150K service. less shelf life and ultimate service life than OAT.
Dexcool-OAT. 2EHA, sodium neodeconoate, or sebcate. OE used. readily available and in concentrate, inexpensive. Probably slightly more agressive with some plastics than Green or G-05. Can sludge in air. long shelf life and service life 5y/150K. Well tested and proven to prevent corrosion. no silicate, phospates or borates. Probably has a high compatibility with other coolants. Morre tolerant of tap water.
Asian vehicle formula-HOAT. sebacate and phospate, no borates or silicates. OE coolant. Pre-mix only, limited availability and high price. Best only in late model asina vehicles. Probably as agressive with plastics as dexcool. Won't sludge in air. Long service life ~5y/100k miles.
Peal Global- OAT. Benzoate and some other unkiwn inhibitor, maybe sebacate or neodeconoate. non OE. Probably as agressive with plastics as Dexcool. available in concentrate but not readily available. may not sludge in air. silicate, phosphate, borate etc. free. Probably more compatibility with other anti-freezes. Long shelf life and service life, and more tolerant of tap water comparable to Dexcool. I don't really see what advantage it gives over Dexcool other than maybe being less likely to sludge in air.
OK that's my opinion and belief of the common anti-freezes.
