The US Army's Search for a Universal Extended Life Coolant Specification
AFAIK, it’s nylon and silicone that are the most susceptible to 2-EHA damaging them(see: GM LIM gaskets) but radiators use PA66/GF33 tanks. BMWs do have their coolant reservoirs fail, the G-48 coolant used for the last 30 years in those is a 2-EHA SiHOAT.
Now, Permatex claims their latest RTVs(Optimum and Right Stuff) is “resistant to post-Dex-Cool modern coolants” but that be meaningless. The solution to contain 2-EHA is FKM fluoropolymer per 3M and Fel-Pro seems to agree as it’s their preferred elastomer for the problem child GM engines with Dex-Cool.
BMW switched to HT-12 in 2019 I believe, which is 2-EHA free.
A little better explanation on why the saltwater test may be important:
Interesting Op-Ed there, and it fits nicely into the theme of Army self-criticism/improvement.
It's certainly true that military engines are more likely to be filled with poor quality water, but I don't think that was the primary motivation for the focus on this particular test.
The reports authors stated that:
"The results of ASTM D4340-19 with the blends are important because this study was designed using existing coolant compatibility tests performed by OEMs, which can be found in their coolant specifications."
From what I can tell ASTM D4340 was introduced pre-1990, and I found a reference from 1993 about using it to test compatibility of a candidate 2-EHA formulation with conventional coolants.
I was not able to see the reference for some reason.
My post was in reference to high salt concentration in the water only and why poor water quality is less of a concern in regard to Army engines in comparison to personnel. Just a thought, since @JHZR2 brought up the question regarding high salinity.
During my time, BDAR fixes used whatever was available, to mix with whatever was available. Creek water, grey water, etc., along with whatever supply had in stock if it was even available. The only concern was to get out of the area and concentrate on personnel first.
I suspect the idea may be that in a hostile environment, a BDAR fix is implemented (punctured radiator), but not all coolant is out of the block/system. Whatever water is available is added so the vehicle can depart the area ASAP. In that circumstance, gelled coolant two minutes later would be a big problem.
For example, a radiator puncture (regardless of cause) is repaired by punching out the fins in the area and bending the tubes shut. Less than a minute. Refill with whatever and get back to the mission (retrograde or otherwise). If saltwater would gell the AF in the system, that would be a very big fail.
"Mixing effects were examined by combining coolant 2 with two conventional North American coolants. ASTM D 4340 was used to evaluate performance. Representative samples of the North American coolants were obtained in the aftermarket. The North American coolants were phosphate buffered and had both high and low silicate levels. Theses coolants passed ASTM D 4340 when tested alone. In all cases there was a range of mixtures with corrosion rates greater than the specification for ASTM D 4340 in ASTM D 3306 (1.0 mg/cm2/wk)."
There's more but I don't feel like typing it all out, it's an interesting report about the early investigation of OAT coolant including 2-EHA, even if there are some pages removed.
Yes, it certainly is more of a concern, which is probably part of why they decided to run the D4340 test again on non-mixed samples of the two downselected candidates:
"ASTM D4340-19 is a screening test used to evaluate a coolant’s ability to prevent corrosion of aluminum. This test method was run under WD 002 on all the ELC blends, but since it had not been run on the pure candidates, which is a requirement of ASTM D3306-20, it was decided to run ASTM D4340-19 on each OAT candidate individually as well. As expected, just like when the two candidates were blended together, each one alone produced passing heat-transfer corrosion
rates (the highest result being 0.3 mg/cm 2 /week) and no precipitates were formed."
There's a lot of good info hidden away in military training publications, I've ran across some BDAR ones before and they were quite enlightening.
