coolant drain and refill 2017 Elantra
New Jersey
Hi,
As my 2017 Hyundai Elantra Value Edition approaches 60K, I plan on having the coolant drained and refill. Is the safest bet to use my dealer for this service, or can I trust a reputable trusted independent shop to use the correct coolant and mix?
Is the 50/50 premixed from Peak or Xerex, just as good as using the concentrate and adding the water for the correct mix? Someone on here said
the 50/50 premixed stuff is crap.
Thanks
Michael in NJ
The 50/50 premix contains the same coolant as the concentrate but in an easier-to-use formula ready to pour into the radiator. All you have to do is drain the radiator and refill. The Lisle Coolant Funnel is awesome :)
As you said, both Peak and Zerex are good stuff, as is Pentoforst A2
I didn't know Hyundai still required coolant every 60k! Most modern coolant intervals are 100k now :unsure:
