What exact coolant type for 2017 Elantra SE?
New Jersey
Hi,
My overflow coolant reservoir is almost empty. What is the proper EXACT coolant for the 2017 Hyundai Elantra SE 2.0 engine??
Is it the green, blue or red??
Thanks
My 15' Sonata took green coolant. I haven't paid attention to the Genesis, I think it's different.
I'd just top off with distilled water and plan a coolant change at some point.
I've been using Pentosin A2 in my Hyundai and Kia. You could probably use Zerex too, but I would drain the system for that one.
its green... I suggest get the Hyundai High Mileage coolant. The last time I checked it concentrate so you will need to mix it with distilled water..(50/50)
Hi,
Thanks
I used this version from Peak. It took a VERY small amount to top off to the "F" line in the overflow reservoir. I guess the coolant in the overflow reservoir evaporates a bit after 3 1/2 years?? The radiator itself is full and there are no leaks. The coolant inside is green NOT blue, so I assume this is
the correct coolant.
