- Joined
- Dec 7, 2008
- Messages
- 5,523
It's looking like I'll need to replace the front control arms on my 2015 Accord with only 91k miles due to some thumps, wonky handling and weird inner tire wear. This is apparently a known issue with the large compliance bushing on the front that is not replaceable for some reason.
Yes, OEM is always the right answer, but replacements from Honda are $325 each while ones from Moog and Mevotech are only about $80 which is a big difference.
Ball joints are pressed into the knuckle and don't get replaced with the control arms in this application.
What's the concern with aftermarket parts in a case like this? Steel and/or weld quality? Bushing material? Correct geometry?
