Hi,
For quite some time, I am considering buying a Miata, manual, to put back some life in my life.
After some research, I stopped my choice on the years 2001 to 2005 (second generation except the first two years), with a 6 speeds.
I found one close by, a little bit expensive (but they all are), and I will go see it on Sunday. It is a 2001 with 90.000kms (56 kmiles) on it.
I talked to the owner over the phone, and except oil changes (I believe every year as he put about 5 kmiles on it on average every year), and changing the coolant two years ago, he did not do any other maintenance on it. And alignment last year when I put new tires on it.
First thing: Timing belt is original so it needs to be changed ASAP. How much is it on average as I want him to either make it done or pay for it?
Other things: No change in either brake, manual gearbox, rear diff, and power steering fluids. It will probably be harder to make him pay to make change the fluids, but my main question is how much will it cost me to make it done (especially the gearbox and rear diff as I may be able to DIY the rest), and more importantly, what is the risks I could face changing these fluids this late in the life of the car, later on, compare with one which got more "normal" maintenance?
I heard that changing fluid in an old gearbox could make it slippery and not workable as the dirt in the old fluid helped it going. Myth or reality?
Knowing the no maintenance history of this car, what will you look at on the car when you will inspect it to know if this is a Go or NOGO?
Thanks for any advice.
