Originally Posted By: KenO
Originally Posted By: TFB1
Last engine I cleaned sludge(and I mean remove valve covers and actually check) was a 3.3L V6 Chevy, that was in 1986 or '87... Generally with regular oil changes and oil from this century, sludge is a non issue...
Not true at all. There are some motors that are simply known to sludge. Using conventional oils for extremely long drains (say, some dummy puts conventional in a BMW or Lexus or something that calls for syn on a 15-20k mile change interval, and goes that long on it a few times). Sludge absolutely happens. When I pulled the intake on my '97 Silverado to do intake gaskets there was an inch (or more) of sludge in the lifter valley. Enough so that before I put any go-fast parts in the motor it's going to be completely torn down, cleaned, and reassembled. My luck I'll put a nice cam or swap the heads on it and THEn it'll dislodge some sludge and plug the oil pump and starve it
And how much of a intake coolant leak did that Chevy have??? And also what oil OCI?? No small block Chevy should be a sludger, the V6 I had no doubt had been neglected... Since I've gone back to the Blue Oval none of my approx 25 Fords have had sludge problems(this includes several I resold), nada, zero, none...
I wouldn't have been surprised if there had been some sludge my F-150, as it likely had not seen a change in two or three years before I became owner(less than quart in pan), but inspection into the oil pan showed it was clean... Can't see anything through oil fill and PCV still functions as it should, I'm not touching the top end...
Also note I said regular intervals, prior to SL oils that was(or probably should have been) 3K mi for most of us...
