Compressed air or electric
Canada
Is there any benefit to going with compressed air over electric impact sockets etc.?
Considering a year long project that will involve a lot of taking parts off of my old BMW including suspension, engine, trans etc.
There's currently a sale at CT where I can purchase an air compressor and impact etc for a fraction of regular price.
This will greatly make the project MUCH easier! OR I can go with an electric impact....
Please let me know the pros and cons of both.
thank you
I decided to go with air as I already had a compressor, that and I haven't been happy with the cordless (Milwaukee and DeWalt, both 18V 1/2") ones we have at work. They work ok for removing sorter slats or machinery guards, but lack on everything else. If we're working on an electric tugger I need to break out the old Ingersol 1/2" air.
I have a 1/2" stubby from H-F and its been stellar. Much more compact than a cordless and has plenty of oomph; it even took off a stubborn front axle nut on my Tacoma.
Life is short--get both.
Or I should say, buy as stuff comes up on sale. I recently grabbed a 1/2" Makita impact from Home Depot, 260ft-lb, with battery and charger, for $149. Matches the drill and 1/4" impact that I already got, and have been using on a regular basis, so another battery and charger kinda made it a no-brainer, IMO. That said, I still have my 20 gallon compressor (a cheapo oilless one, it was a gift from the spouse) and a 1/2" HF Earthquake for when the going gets tough. Or tires need to be aired up.
I'm guessing that if you run the numbers, "big" powerful electrics are still more expensive than a cheap air setup. I haven't run the numbers so I might be surprised--the electrics keep coming down in price and up in power.
I have a Dewalt 899 electric and several pneumatic 1/2" guns - Matco, Craftsman, IR.
I like both. Nothing wrong with big guns.
I have the kobalt corded 1/2" impact gun. It's a complete beast for the little I use it I'd never go air again.
Advantage
You have all the stored energy in the air tank, more power
Tools if oiled once and a while last forever
Disadvantage
Hose
Waiting for the compressor to pump up
Advantage
No Hose
Disadvantage
Less power
Run time
Waiting for battery to charge
Battery wear out
thank you
First, when you say "electric" are you talking battery or 120VAC corded?
With torque being equal and standard.
Air guns are generally lighter and cheaper but require a compressor, dry air and periodic lubrication for optimum performance. The duty cycle is only limited by the compressor.
Battery units are infinitely more portable but the battery loses electromotive force as it drains plus that's a cost and they do expire requiring replacement. The duty cycle is limited by battery charge/load ratio and the number of good batteries plus recharge time.
Corded units are heavier but usually have no limiting duty factors, but are subject to load and line issues as with any extension cord. Wet environments can present a safety issue more than the others. They wear out and often have to have brushes.
What's best is in the eye of the beholder but I would recommend air when looking at all things equally EXCEPT when working remotely.
If you have big jobs to do and can reach them with air hose go air. Not just for impact drivers large and small but for die grinder, air hammers, needle scalers, paint sprayers, drills and a ton more. I bought most of my air tools 30 years ago and they are still working just like new. Even if you dont use them for a year or 2 they still work when you pull them out.
Good corded tools are great but they get expensive if you need to buy a large variety and are always heavier than the air version, they last for years and are only slightly less reliable than air if taken care of.
Battery power has its place, they are way more portable and you can use them anywhere without tripping over cords or hoses and they are more convenient for those quick jobs but they can get expensive. I have never had a decent cordless tool break and yet I have had to buy 3 sets because they discontinue batteries or chargers. I still have my old Dewalt 12v drill but have had to rebuild my battery pack 4 times, if the charger gives out its done. The old Nicad batteries were always dead when I needed them so I had to wait several hours for them to charge and usually ended up with a corded tool. The new lithium is much better about holding a charge but they dont suffer drops too well and are more expensive when you want to buy a spare or 2 but if you need remote use like the side of the road or out in the field or up on the roof nothing else compares.
thank you
Sorry, i meant to say "corded" as I don't care for battery packs, especially when the temps get a bit chillier.
These are the products I'm considering...all currently on sale
Corded:
https://www.canadiantire.ca/en/pdp/...rench-1-2-in-0542099p.html?rrec=true#spc
Compressors:
https://www.canadiantire.ca/en/pdp/mastercraft-8-gallon-air-compressor-1-5-hp-0589316p.html
Of course, then I'd have to invest in a gun, and air line etc.
Either way, i'll also have to get a set of impact sockets
These seem decent.
https://www.canadiantire.ca/en/pdp/maximum-3-8-in-1-2-in-impact-socket-set-83-pc-0589444p.html
Either way, i'm not interested in starting a collection of tools and after my project is finished, i plan on selling the impact tools.
Mostly because I have no place to keep them, and i don't care to do this type of work again.
Corded:
Compressors:
These seem decent.
Either way, i'm not interested in starting a collection of tools and after project is finished, i plan on selling the impact tools.
If that's the qualifier then buy the electric. To do what you want that A/C listed will be woefully inadequate in pressure and duty cycle so you would need a much bigger unit in HP and tank size for impact tools. ( unless you don't mind waiting for pump ups)
Just on single event and price point- get the corded with about a #10 extension cord.
I have both compressed air and cordless electric impact wrenches. I find myself reaching for the electric one more and more frequently. I like having both types, but if I was starting over again, I would purchase only the electric unit.
By the way, that compressor that you have listed is way too small for any significant wrenching.
Electric should have all the power you need for automotive work. Only place you may need a compact unit for is on a harmonic balancer. Check your clearance.
You have to factor in the replacement costs of batteries over time. Might have to replace them every 5 years, and after 15 years there's no guarantee you'll even be able to get replacements. Air tools should effectively last forever if maintained and the air connection standards should be the same even 50 years from now.
I will revamp my post above. If you only need short term and only 1 tool with no place to store then definitely go corded electric.
The air compressor will be useful for other purpose than just running a tool.
I have used my air compressor to stain the fence, clean a whole lot of things, etc.
Yes, the battery powered tools have its purpose because you can use it inside the house.
So I have both for different purpose.
I used air impact but for taking off For difficult nuts/bolt.
I used battery powered small impact tool for small nuts/bolts.
The compressor can also be used for air nailers.
Both have their place.
Corded tools are cheaper to get into, and more expensive in the long run. By the time you get the entire tool set, and a substantial set of batteries to run them, the motors start to wear out and the earliest batteries are dead and the middle set of batteries have low endurance, and then the entire system is discontinued.
I find the big battery gets in the way with big powerful corded tools, more so than the cord.
Air tools don't overheat (their cutting edges can, but not the tool), as they are continuously cooled by expanding air.
Nonetheless, cordless tools are prevailing in the marketplace, because the initial entry price is cheaper.
??? If there is a battery, there is no cord.
I don't see how anyone can do major repairs without compressed air? The first thing I do before tearing something down is blow all the debris off the component.
