As most people know, Kendall is now owned by ConocoPhillips. They also own the "76" brand.
I checked the ConocoPhillips website for specs on these oils. I suspected that even though ConocoPhillips sells motor oil under four different brand names (Conoco, Phillips 66, "76" and Kendall) they were probably the exact same oil. Management is always looking for a way to save money, and consolidating operations is a big part of any acquisition/merger to cut costs.
Sure enough, when I checked the 5W-30 full synthetic oil for these brands, the specs were identical for each one.
SAE Grade 5W-30
Specific Gravity @ 60°F 0.853
Density, lbs/gal @ 60°F 7.11
Color, ASTM D1500 3.0
Flash Point (COC), °C (°F) 235 (455)
Pour Point, °C (°F) Viscosity, Kinematic
cSt @ 40°C 60.0
cSt @ 100°C 10.5
Viscosity Index 166
Cold-Cranking Viscosity, cP @ -30°C 4,250
High-Temp/High-Shear Viscosity, cP @ 150°C 3.0
Sulfated Ash, ASTM D874, wt % 0.97
Total Base Number (TBN), ASTM D2896 8.1
Phosphorus, wt % 0.077
Zinc, wt % 0.086
Conoco
http://www.conocophillipslubricants.com/...20TDS%20Web.pdf
"76"
http://www.conocophillipslubricants.com/...20Oil%20TDS.pdf
Kendall http://www.conocophillipslubricants.com/...20TDS%20Web.pdf
Actually, I didn't even bother to look up the specs on Phillips 66 synthetic, since I am fairly sure it is the same as above.
I think a lot of people might be surprised about which oils are really the same.
SAE Grade 5W-30
cSt @ 40°C 60.0
cSt @ 100°C 10.5
Viscosity Index 166
Zinc, wt % 0.086
Conoco
"76"
