M Marc Hufnagel Joined Oct 11, 2020 Messages 15 Jan 26, 2024 #1 Needing a recommendation for a break in oil for a Coleman/tao Tao 196cc mini bike. Calls for 10w30. Last edited: Jan 26, 2024
Creekside Joined Jun 12, 2020 Messages 1,453 Location SW Missouri Jan 26, 2024 #2 Whatever you can get cheap. It'll probably make a lot of metal for a while.
Rogueman2016s Joined Sep 24, 2023 Messages 1,267 Location South Carolina Jan 26, 2024 #3 Marc Hufnagel said: Needing a recommendation for a break in oil for a Coleman/tao Tao 196cc mini bike. Calls for 10w30. Click to expand... Any conventional will work.
O oil pan 4 Joined Feb 24, 2005 Messages 1,417 Location eastern NewMexico Jan 26, 2024 #4 Get some sj or sh rated lawnmower oil. An oil that ends in 30 should be fine for a mini bike.
F fozzdesy2001 Joined Nov 22, 2013 Messages 262 Location York, Pa Feb 2, 2024 #5 Pennzoil {PYB conventional} 30W or 10W-30 change it often at first like after the first tank of gas then every other for 3 quarts of oil. This will flush out the break in ware metals, oil is cheap, and this engine doesn't hold a lot. ]
