So winter fast approaching I have to ask this question.
I realize that almost all the tear and wear of a engine will happen when its first started and very cold. So check it. I have a 03 Nissan Sentra SER Spec-V QR25DE, currently filled with Mobil 1 0w-40.
To start my car I have a CRAZY system.
1. Insert key to ON position, allow fuel pump to prime and diagonistic bells to finsh ringing.
2. Pull Key out and repeat step 1 (double prime the fuel pump)
3. Making sure all accessories are off (no radio, lights, heat, cold, anything) with the transmission in neutral, turn the key and start the engine, do not turn on the heat or activate any accessories, allow the engine to reach a moderately warm temperature.
After this I drive the car very delicately in the cold weather, No shifts above 3,000 rpm. (6,200 being redline)
Is there anything else I can do to minimize strain\wear\tear on my vehicle when cold starting?
