Fairly new and starts just fine if it's not below 30 or so. The battery is new.How old is the alternator?
Apparently the hair dryer trick worked this morning in the 14F cold. After heating the lock mechanism with a hair dryer for a few minutes it fired right up.I think you install a fixed resistor then turn key on and leave on for an hour until the PCM sets up to accept the new resistor value. The anti-theft "key" light will go out and the car can be started. This was standard for aftermarket remote start kits that require enabling the PCM to start without turning the key.
But as noted this is all antique history by now.
The only caveat is that the ignition tumbler has a hall effect sensor built in. It's known to go bad. This morning my dad and heated the lock mechanism and after a few minutes it fired right up.This is a really basic system that only detects if there is a key in the lock cylinder or not, it's just enough to keep the Kia Boyz away. Inserting a key, any key completes the circuit and let's the cluster know if it's okay to allow the vehicle to run. There's no resistor like earlier systems and no transponder like modern systems. It can only be the cluster, lock cylinder or wiring.
Try the hair dryer trick if it's cold outside. This will eliminate if it's the pcm or the hall effect sensor.Sub'ed as my neighbor has a '00. The key cylinder is the typical do-a-dance-to-turn, but works. But would be good to know how OP resolves his issue!!
I've replaced the lock assembly but it won't seem to relearn. The anti theft light is supposed to flash then go out after 10 minutes but doesn't. This is supposed to be a straight forward repair. Any thoughts?Can you see if a bypass works or have you already tried it? Something about putting a resistor in.
I had that happen to my old suburban with passlock 2 once when the battery shorted. My mechanic told me to do the relearn and gave me the directions and if it didn't work then to let it sit without power for an hour and do it again but it worked without needing to disconnect and wait. But if something wasn't wired right or the hall effect sensor doesn't work it could be a bad cylinder as new parts aren't great these days. There are different relearns so maybe look through this.I've replaced the lock assembly but it won't seem to relearn. The anti theft light is supposed to flash then go out after 10 minutes but doesn't. This is supposed to be a straight forward repair. Any thoughts?
There are about 10 different resistance values. If you didn't replace the cylinder with one the same as the old one, it will need to relearn.
If the cylinder is bad (infinite resistance) that is not a valid value and it will not learn.
According to a few GM forums there are as many as 15 different resistor values. Several articles more or less say there's always a relearn process. The non-blinking anti theft light is what's throwing me. A bad part is possible, but I've come across two posts online that says it may need a professional mechanic to sync the vehicle. Quite frustrating.There shouldn't be a relearn. You might have a bad lock cylinder.
How do I test the cylinder resistance? Unplug the harness and put leads across them?
So the hall effect sensor was bad. It wasn't correctly crimped to the tumbler.
Funny you say that as there are two black and one white wire on the harness, no yellow.It's been a while, but I recall cutting the yellow wire while it's running cripples Passlock's ability to interfere with your car running.
Please remember that Passlock and Passkey are two different systems; Passkey is "better" and has the resistor chips in the keys. Passlock is GM ripping off their own intellectual property to sell a cheaper system.
So the hall effect sensor was bad. It wasn't correctly crimped to the tumbler. View attachment 313751
