Gentle in our little protected slope so far
Is that a typical set-up for a softener there to drain outside? Never seen that before. Mine just goes into a floor drain in the utility room.Yeah the plumbing is easy. Cold is the pain. Getting some insulation on the 1/2" pipe coming out and down behind the heat pump was pretty tight.
Weirdass melting going on
My softener (KCl) and de-sulfur (air oxidizer) units are typical resin bead beds that need flush and recharge - the joint flush pipe comes out from my water corner there, through the wall and to ground drain (shared with a couple gutters on that side)Is that a typical set-up for a softener there to drain outside? Never seen that before. Mine just goes into a floor drain in the utility room.
Gutter downspout for front part of garage was frozen solid as an ash baseball bat. Tried whacking it to no avail but hit it with the heat gun seems to have it flowing.
Air temp is 28°F but water now running off roof.
I’ll trade you our 0F weather and 2” ssnow we have
That’s interesting and certainly no worse than my system. My system uses NaCl and is flushing chlorides in my septic tank and field which flow through the gravel into the Kootenay River, then the Columbia River and then into the Pacific Ocean which is probably the same ultimate destination as yours.My softener (KCl) and de-sulfur (air oxidizer) units are typical resin bead beds that need flush and recharge - the joint flush pipe comes out from my water corner there, through the wall and to ground drain (shared with a couple gutters on that side)
I guess not much difference if in the septic flow or not. Maybe less taxing on the system per 100 years hahaha crap I just worry eventually when these drains plug upThat’s interesting and certainly no worse than my system. My system uses NaCl and is flushing chlorides in my septic tank and field which flow through the gravel into the Kootenay River, then the Columbia River and then into the Pacific Ocean which is probably the same ultimate destination as yours.
