HI there.
Before I ask the question, there are a few things I want to mention, so there is no confusion & we don't turn this into a fiasco.
I know and WANT to use oils that meet Ford WSS-M2C929-A and/or the "new" WSS-M2C946-A which superceedes the previous. I WANT an SN rating and at least a API CF rating. I also want to use an ACEA A1/B1, A5/B5 spec. Therefore, we just knocked out the "High VIS" A3/B3/B4 oils and are dealing strictly with "low viscosity oils". These are what my Jaguar manual requires for both Jags, and that is what I wish to stick to.
My goal is to find the "thinnest" oil possible that meets those specs COLD and that is in the 30 weight category HOT.
My manual "prefers" 5W30, but it also states 0W30, 0W40 & 5W50 as alternatives. I have been running Castrol Edge religiously in both Jags, and changing oil and filter every 5000 miles.
This is mainly about going from 5W30 to 0W30 on the assumption that a "0" W*** will be "thinner" at "cold" startup.
Unrtil this.....Okay lets look at the following:
Mobil 1 5W30 Viscosity @ 40*C, cSt 61.7
Mobil 1 AFE 0W30 Viscosity @ 40*C, cSt 62.9
Castrol EDGE 5W30 Viscosity @ 40*C, cSt 62.6
They all run at or around 10.* HOT, so that's not a big deal. I understand they ALL protect the engine pretty much the same at running temperature. It's the symphony of valvetrain noise at startup I am trying to address, or at least reduce.
Now I ask, How the heck is a 5W30 actually "thinner" than a "0W30" at 40*C?
The whole idea in moving to a "0W" weight is to get a more "liquid" or faster flow at COLD (or starup) over a 5W, at least I thought...
If I read the specs correctly, I basically didn't change anything as far as my fluidity at cold startup if I go from a 5W30 to a 0W30 (according to the specs above) - which is what a "0" weight is all about anyways???
How did they get the "0" weight on Mobil 1 AFE 0W30, when the 40*C viscosity is actually a bit "thicker" or flows a bit "slower" than the 5W30??
That is my main question. Comments & suggestions are welcome.
One "off the wall" question.... even though 0W20, 5W20 DO NOT meet the WSS specs I mentioned earlier, would there be any harm, or what would happen, if I went to a **W20 grade?
Oh and BTW, this is a SUPERCHARGED Jaguar, driven rather enthusiastically at times. So lets keep that in mind.
Thank youin advance for your thoughts.
