Yes I considered the Comp 252 but I don’t like the single pattern, .425 lift, and 110 LSA. I’m looking at the Melling SPC-4 with just over .400 lift, 111 LSA, and 198 - 208 @ .050. Should idle smoothly with vacuum for power brakes and the ability for the carburetor to truly run (lean-not stinky) on the idle circuit.The 066 (code N) is a perfect grind for your use, gear ratio and car weight. I don't know of a current Melling equivalent, the MTP1 is a bit hotter. Alliance Cams and Wolverine used to have a 066 equivalent but those shops are long gone. The MTP1 is identical to the old TRW TP190, a very popular grind in the larger 400. As I mentioned above, that Melling is the most you should use and given your experience already with too much camshaft I'd go even more conservative, the 066 if you can find it, or the Comp 252.
