I'm running a recently (1 year ago) remanufactured Ford big block 385-series 460 engine in my carbureted 1982 E350-based Motorhome. The engine was remanned to essentially stock specs except for a Melling MTF-3 torque camshaft with valve spring loading pressure when open of 255-280 psi according to the manufacturer. The cam timing is adjusted to 2 degrees advanced, the intake is an Edelbrock Performer and the carb is a custom tuned Edelbrock 1406. Finally, there is a set of Hedman Elite headers and essentially all smog equipment has been disabled. The 14,000 pound Motorhome has a C6 transmission with a Gear Vendors Overdrive and a Hughes FXM torque converter.
Since the break-in oil change, I have been using Rotella T6 15W40 oil in lieu of the high ZDDP levels and elevated temperature levels experienced by the fairly stressed engine. I now understand that Shell Rotella T6 15W40 has gone to grade CK-4 and as a result, the ZDDP levels have been significantly reduced. I have been looking at other synthetic oil possibilities that would supply high-temperature compatibility along with a balanced oil additive package that included elevated levels of ZDDP in view of the flat tappet design of the 460 engine. I am a member of the focussed website "460Ford.com" which is a resource of dedicated builders and modifiers working exclusively with the 460 engine and they have no reservations about running higher viscosity oils including 40 and 50 grades. The original factory spec called for 10W30 back in the day. In this search, I have been drawn to Castrol Edge 5W50 Synthetic oil which is specifically described as designed with a high ZDDP additive package to support Classic Cars with Flat-Tappet engines. However, I see virtually no discussion or mention of this oil on this site. If have two questions: What is the group's assessment of Castrol Edge 5W50 in this application for Flat-Tappet engines? and What would the group's best oil selection be independent of the Castrol suggestion?
Thanks for your help!
