ONE thing should be remembered . . . that oil specs from OEMs do change from time to time. The particular OEM spec was in place at the time the vehicle was produced, but could well have been upgraded/superceded with later model years. This particular spec was for 2013 model year and possibly for several model years prior to that.
The reason that many "common" conventional oils meet it is that it could well be "a weak spec", as mentioned, at least in more recent times. Dexos1 is a semi-syn spec, not a dino spec, for example. Dexos1 replaced TWO GM oil specs, including an earlier syn spec, I believe, plus a prior dino spec, too.
Another thing is that OEM oil specs are "minimum specs" for warranty coverage AND what the OEM used to do the EPA emissions and fuel economy certifications with (especially viscosity!). Chrysler used to spec a Mobil 1 product for SRT vehicles, but went to a Pennzoil product Upon looking at Virgin Oil Analysis to compare the additives in each, the Pennzoil product had a different certification related to longer catalytic converter life (from what I found) . . . again, warranty and emissions issues.
Check the various websites for the oils you would like to use. Check the approvals THERE as to change what's on the bottles can be MUCH harder to get done.
