Chevy LS engine oil pickup O ring replacement on 4x4 trucks
I’ve done 1000 miles in the last two weeks and the oil pressure is holding up fine. Also all is well with the front axle and U joints which is comforting after dropping it several inches to allow the oil pan to be dropped. 🙃
When I did this job on my 2004 I just completely removed the front axle and let the cv shafts hang but I did tie them up so they weren’t hanging.
It’s one year later. The hot idle is shown. Still good. The oil pressure while cruising is about 38 psi with 5w40 motor oil with 4,000 miles on it.
