- Joined
- Jan 29, 2022
- Messages
- 243
So I drive a 2001 Chevy Blazer 4x4. 4.3 vortec with 114k original miles. I’ve been daily driving this truck for about 2 1/2 years. The truck did sit for a couple years prior to me buying it, so that is probably one of the reasons why this thing leaks as much oil as it does. Not enough to really puddle up on the driveway, but the whole oil pan, and the rear main seal bell housing area is soaked in oil.
This thing had oil leaks here and there when I bought it, and it seems the oil leak is getting worse.
This thing has very low miles for a 2001 vehicle, and I would really like to keep this thing till the wheels fall off. I don’t want car payments, and this truck has been great for me. Perfect size for me, and it just works well for me. It’s clean, it’s got zero rust, so I really don’t want to get rid of it, and also not looking forward to buying a newer car, and having to make payments.
So I would like to keep the blazer long term.
The oil pan gasket, oil filter adapter gaskets, the rear main seal, and the front timing cover seal are all leaking quite a bit. I would like to get it all fixed, but unfortunately on a 4x4, it’s really not easy to do at the home garage.
So I will probably take it to a shop to get all the oil leak concerns fixed.
About how much would the labor be if hourly labor rate is somewhere in the $180-$200 range?
I would rather spend a couple thousand to get the oil leaks fixed on this thing, because it runs awesome, and it should last a really long time. And it’s cheaper than a car payment.
If any of you have access to all data or an equivalent software that can come up with an estimate for rear main seal, oil pan gasket, and front timing cover replacement on a 2001 Chevy Blazer 4x4, I would really appreciate it.
Thanks in advance!
Thanks in advance!
