- Joined
- Feb 15, 2025
- Messages
- 268
I always thought the oil dipstick reading would be somewhat similar from cold to hot readings, but I have some difference on my new car.
If I read the dipstick cold after sitting overnight it is slightly under the full mark. I believe oil expands as it is heated, but more oil should drain back into the sump after sitting all night. When oil is hot it may expand but more oil remains in the upper areas of the engine 5-10 minutes after shutdown. In my mind it should be a wash but the oil level reads a bit higher when hot shortly after shutdown. I may try checking the oil level when warm, say 1-2 hours after shutdown, but not totally cold, and see how that compares.
What is the preferred method of checking oil ?
