Oil quantity, Ford Godzilla V8
Colorado
Yesterday morning, after the E350 sitting all night, I drained the oil, dropped the oil filter. TIghtened the plug, spun on the new filter and poured in two..... one gallon jugs of motor oil.... 8 quarts. I ran the rig for about 100 miles, pulled over and checked the oil level and it is barely hitting the very bottom of the dip stick.
Should I be concerned????
Manual says I need 8 quarts with a filter change.
How many minutes did you let it sit with the engine off before checking the oil? And are you certain it was a pretty level surface you were on?
You didn't check the oil after the oil change?
My 21 silverado 5.3 calls for "8 quarts" with a filter change as well but the reality is that if I let it drain for an hour it will often take 8.5 quarts and maybe even a tad more to reach the full line so I wouldn't be too surprised if other vehicles were similar. sometimes draining for longer will empty the oil pump and pickup tube, perhaps an oil cooler as well, all of which isn't factored into the typical oil drop and refill you get at an oil change shop
My Tundra has a nominal 8.0 quart capacity. If I let it drain for a long time, it takes 8.5 to bring it to the top of the line.
Concerned no, but I would add an extra 1/2 quart to satisfy my OCD.
Many people think when they drain an engine its empty, but not true. The change spec and rebuild spec can be different by quite a bit. My Nissan 4.0L rebuild spec is more than 1 quart over the oil change spec.
Lesson learned: check the dipstick after an oil change.
You definitely want it on the safe range of the dip stick. The capacities in the manual are to give you an idea how much oil is needed. But the actual amount varies.
You're saying the people who designed the engine are wrong on the amount of oil to put in?
For my Ram the dipstick is way off compared to the manual's guidance. I marked my dipstick with a scribe after putting in the proper amount.
I wouldn't say they were wrong. but there's too many variables for them to provide a super accurate capacity for normal maintenance. For example, how long you let it drain, slight incline/declines, etc. In the owner's manuals I have from Ford and Nissan, they generally say "for approximation purposes" and "use dipstick to determine proper level" or similar under the capacity specifications section.
I wouldn't say they were wrong. but there's too many variables for them to provide a super accurate capacity for normal maintenance. For example, how long you let it drain, etc. In the owner's manuals I have from Ford and Nissan, they generally say "for approximation purposes" and "use dipstick to determine proper level" or similar under the capacity specifications section.
A small amount in the pan should not make much difference unless it has a trapped area or something similar. If I were to use the dipstick hash mark on my Ram the pan would be underfilled by quite a bit. I would think the dipstick manufacturer's quality control would vary widely compared to the engine itself.
Agree to disagree. An age old debate here.
From my manual "Approximate dry fill capacity. Actual amount may vary during fluid changes."
Also, could anyone ever argue with a straight face that any mekanik was negligent or irresponsible by following the dipstick? That's why it's there.
Say someone pulls in with unk mileage on the oil and just wants you to check the level. You're not starting from scratch -- you're just adding to existing oil. What are you to do? Use the dipstick, presumably.
obviously we're excepting vehicles which have no dipstick and simply tell you oil level on the dash or via other means
No, I never check my oil level right after filling the sump with the exact amount the owners manual calls for. I drive it 20-100 miles and then check. Why should I be worried???? Drain the oil and pour in 2 gallons.
The big difference here is ..... I let it sit overnight before I drained the sump. Never done that before and I think that is the big difference here.
Why did I wait overnight????? Because I was in an RV Park, changing my oil at 6:30am and didn't want to fire up the engine to warm up the oil and wake everyone up. The 5w30 flowed out just fine completely cold.
Tomorrow morning, I will check the oil level again, after sitting overnight and see what the ole dip stick says. I am guessing it will be right in the middle of "OK".
I did swing by a WallyWorld today and picked up a single quart.... just in case.
We are just over 5,000 miles of an RV touring trip of the Eastern US and it has been spectacular. We have another week and a half of exploring to get home. The Godzilla has been phenomenal!!!! We are averaging 10.6mpg so far. (My son get about 7mpg in his Class C with the old V10.)
Ok... I let the rig sit overnight and then I checked the level on the dip stick and it was still at the very, very bottom. I added a full quart and that brought it up to the top divot on the metal of the dip stick. Then I drove it for another 2,000 miles... til today.
Not sure what to think... Is this really a 8.5 sump??????? 9 quarts to the very top?????
The last thing you do after changing the oil is run it and then check the oil level. I always let it sit for 10 min to let the hot oil drain back.
Engines all have varying amounts of oil that remain in the various passages, the lifters, oil pump, etc after you drain the oil. The factory fill amount is typically a quart of more than you normally get out during a normal oil change. Letting it set overnight got more out than you typically drain out. I'm guessing you let it sit overnight with the oil filter off?
