- Joined
- Sep 23, 2017
- Messages
- 429
Hey all I have a 2022 Range Rover sport 5.0 v8 supercharged and I don’t have a local Range Rover dealer to get the oil change done so was going to take it to a local shop most probably but was wondering if anyone has done it on these trucks themselves, is it just the simple pull the plug from the bottom, drain, change filter, add new plug, add new oil? I just wanted to research to ensure the job is the same/common so that the local shop can do it and I can trust they did a good job
The truck engine has basically been the same since 2013 ish so I bet someone has a similar year truck with the same engine that can chime in
My plan was to order/ship the oil from the dealer to my house. Was going to order 9 quarts of oil ( I believe the truck needs 8.5 quarts in total unless I’m wrong) new drain plug, new filter
Is there anytning else I may be missing?
Thanks
Thanks
