I've seen many discussions about changing factory fill engine oil after the initial break-in period of about 1000 miles in a new car. Many people on Toyota Nation forums did this and it generally considered a good practice. I did this too when I got my new 2010 Corolla. I changed factory engine oil with Mobil 1 5W20 synthetic at about 1200 miles. However, I also noticed that generally people do not think about changing the ATF and I believe transmission goes through the break-in process too. So this past weekend I did 4 drains and fills with Redline D4 ATF replacing the factory fill of WS fluid. I had good results - transmission is now a lot quieter and shifting smoother. I also noticed some fine metal powder came out with the first drain which I believe must be the break-in particles. So it is probably a good idea to change the factory ATF to get all the initial junk out of there... Any opinions?
